The last ALPS I bought in that style has a 8mm bushing (0.315") and a 6mm shaft. In addition to being a small metric diameter, the bushing is shorter than most other pots. Adapters to convert a 6mm shaft to 1/4" are common, but I don't know how the other differences will affect mounting in the Citation. I'm working on a situation now where a 0.354" bushing (TT Electronics 9mm) needs to be centered in a 0.375" panel hole. I've decided to cut a thin strip of 0.010" sheet brass and form it around the bushing to take up the slack. You might be able to do something similar. Have you contacted Jim McShane about this? He's the Citation expert. I would be surprised if he stocks these pots, but maybe he knows of a solution, just in case the ALPS is too troublesome.I have a couple of these coming to see if I can get it working correctly
guitarrepairparts.com
I just brought this Citation 1 back from the dead. Having a problem with the loudness (volume) pot. Anyone successfully rebuild one?
What makes a particularly good preamp transformer? Apart from adequate ratings for voltage and current?Many, many moons ago. The power supply and transformer are what really made the CIT I. But there were lots and lots of parts in the signal path. Never had to replace the vol pot though.
Reliability.Apart from adequate ratings for voltage and current?
I thought that was generally an issue limited to inadequate ratings?Reliability.
Not always. Manufacturing processes and quality control affect reliability too.I thought that was generally an issue limited to inadequate ratings?
Manufacturers would always recommend a new replacement.I've seen them with thermal fuses rather than standard but often they couldn't be dug out to replace or bypass it.
The potential problem with those is the thickness they add to the panel. A shoulder isn't required for this application, only a washer that can be inserted into the 3/8" hole with an ID the size of the control bushing.oh, or just use these
Potentiometer Hole Reducer Adapter Bushings 3/8” to 8mm (5 pcs)
These plastic adapter washers convert pickguard holes that were originally cut for 3/8" bushings to fit smaller 8mm metric pots. (5 pcs.) Specifications: Inside Diameter: 8mm (0.315") Outside Diameter: 0.375" (9.5mm) Flange Diameter: 0.540" (13.7mm) Professional installation is strongly...guitarrepairparts.com
and call it a day. I was thinking a nut with that built in essentially.
I have since realized I can simply make a custom washer approximately the same thickness as the front panel. The CNC mill I use for cutting chassis and panels can do this easily. The washer can be cut from either aluminum sheet or FR4 to be sure there aren't any issues with dissimilar metals. In my case, the washer will be captured between the potentiometer's lock washer on the back side of the panel and the trim washer/attachment nut on the front. Its exact thickness isn't critical; it only needs to be slightly less than the panel.I'm working on a situation now where a 0.354" bushing (TT Electronics 9mm) needs to be centered in a 0.375" panel hole. I've decided to cut a thin strip of 0.010" sheet brass and form it around the bushing to take up the slack.
I'm currently working on one of these & this is one of the issues.......one side measures only 100K, the other 138K. While turning them clockwise (increasing volume), the resistance actually rises up to around 170-175K....& not symmetrically.....til about half volume, then decreases to only bottom out at around 70-100 ohms........& yeah, the balance pot is suspect too.It’s all over the place and there are bad spots and you can feel it slightly bind while turning.
I had the pots rebuilt and new carbon wafers insertedI'm currently working on one of these & this is one of the issues.......one side measures only 100K, the other 138K. While turning them clockwise (increasing volume), the resistance actually rises up to around 170-175K....& not symmetrically.....til about half volume, then decreases to only bottom out at around 70-100 ohms........& yeah, the balance pot is suspect too.
What was your final fix?
