In wish I had a big honkin CNC router
C'mon Luther, A scroll saw, 1/4" hardboard pattern, and a pattern cutting router bit could carve those rivers for you.
... they make smaller versions too
I think I have THE perfect speakers for this design. Looks like another project.
Do you guys think a midrange/full range speaker would be good for this horn design? Excuse my noobness.
Companies making the dies for the paper packaging industry usually have Laser cutting machines to cut different thickness plywoods, as used on the dies for flat-bed diecutters.
I suppose it is possible to get one of these companies to cut the boards you supply, provided you supply a drawing as well, for a relatively small outlay.
I´m certainly going to enquire with my die supplier, even if that is only a project for the future.
Jorge
Or, have them make you a steel-rule die, and start whacking out a bunch of corrugated cross-sections for the horn. Seal the cut edge on each slice, laminate them together, and....
I work at a shop with a three big honking CNC routers (one has a 4'x 10' table), two laser cutters and some other stuff. This is a job shop. If you have the geometry getting a shop to cut these for you would be no big deal. If you have some dimensions in mind I would put them into a simple CAD drawing for you. :thmbsp: You got me thinking now.
BTW - Waterjets can cut very thick stuff like 12" or more so you could make this out of one chunk if it was the right material.
Well it's a cool design, But I guess I dont understand why they didn't rout a cable channel for the speaker wires, and mount the driver 180 out from where it is. :headscrat
