the 9 simply has a supertweeter and an extra woofer, so the only differences you'd expect would be at the frequency extremes (and less of a difference in the high end since the regular EMITs can play up to 30kHz themselves). by and large the 8 and 9 should sound very similar. this thread is the first time i can recall reading about AKers implying that the 9 completely outclasses the 8. in fact, some have previously stated that the 8's bass is easier to accomodate in some rooms, giving it a potential advantage beyond being easier to power.
This is something I see a lot on the net. "Should" as in meaning you seemed to have not heard the two in person? I have owned both style of Kappa 9 speakers (bought when they first come out), as well as a recent pair, and recently heard the Kappa 8 a friend has. Amongst other bigger Infinity speakers, as well as other brands.
If music is made to be felt and heard, it means the Kappa 9 has a much easier time in making this happen than it's smaller counterpart. It means it will have a much easier time during heavy bass passages in conveying how the music is suppose to sound and be felt (if driven by proper amps Infinity designed them for). Obviously sharing the same drivers they have the same timbre. For that matter all speakers in the same line has the same "sound" or timbre. Does that mean a Renaissance 80 is better than the 90? Or a B&W Matrix 805 is better than an 801?
BTW, who said anything about being outclassed besides you? I said there is no comparison as the kappa 9 delivers much more at both ends. Just as there is no comparison between the 801 and the 805.
If the human hearing only goes to say, 20khz why would Infinity make a driver go to 44Khz and so on? Because they will be cleaner at 20Khz. Much as the Kappa 9 is as compared, having more drivers to share the load...
If more bass response and cleaner highs is not a great improvement to you, then an amp want help.
Remembering back to the Infinity reps I used to speak to often in Infinity's better days, they would probably wonder how someone would have to waste time explaining to you the Kappa 9 is a better speaker lol... But it is the Internet, full of "Should" and "I Thinks"
BTW, Since a speaker is better if it works better in small rooms and needs less of an amp, the Infinity Minuette is a great pair of speakers that can accommodate small rooms and small amps, maybe consider those to while shopping around.....
