Except for going higher before starting roll-off, that looks VERY SIMILAR to the curve for an original L100, which was in turn, modeled after the response of the Altec 604. Deliberate couple of dB "presence peak" in the 1000-6000 Hz range.
I've found that at least in the HPM900s, the "upper mid" control is very effective at ameliorating the peak. Just crank it down about -2 or so (below "flat" as indicated by the dial), and you can get much better looking curves. From my more limited experience, experimenting with HPM100s, I'd think they probably could be "tweaked" the same way, with the front-panel controls.
BTW: George Augspurger (designer of the L100) indicated (somewhere, but I can't find the reference) that indeed, in the L100, turning down the midrange control about 2 dB, made them much closer to "laboratory flat" response. I also found this to be the case, from listening to them... I almost always like L100s better with the mids down just a tad...
Surprising that the HPM100s don't have more going on above 15KHz. Would have thought a ribbon would go higher than that. Maybe it's just that the ribbon (tiny one in the HPM100) isn't efficient enough to keep up? I know the ribbon in the HPM200 (which has about 8 times the radiating area of the one in the HPM100) certainly seems to have no problem reaching 20KHz...
Regards,
Gordon.
