I believe I can make a credible argument that a simple RTA measurement will tell quite a bit, as well. Since it's in-room including reflections, carefully taken, it characterizes more what you're actually hearing as opposed to the performance under ideal conditions.
Here's the curves for HPM-60 from an earlier thread, the top one showing adjustability. This may indicate the kind of range the designer built into the product family. Looks like you have to crank both mid and tweet down to tame it. You can also see why HPM-60 might be preferred over HPM-100 by some listeners:
Excellent reply Zilch (As Always). When I first wired up my speakers, The highs were "Bright" I guess you could say, And the mids overrun by that crazy freq range of the Woofer. After Schooling myself on EQ hook-up/set-up, And after a week of tweaking, I found "Cutting" the upper range, And increasing the mid points, Really changed these speakers..For the Better. They are'nt really muted, Not the right term, Lets say all the drivers are working as a team now, None are "Ahead" of the others. Using these with just a Bass/Treble knob ain't gonna cut it. Even adding more power to them made me have to "Re-tune" them. They seem very sensitive to change. Room/Location, Even the Interconnects. Any of this make sense. Appreciate your thoughts.
