Congrats are in order. I bought mine used on Agon and it arrived on 1/7/11. I've already cleaned about 60 records and although most of mine are not extremely dirty, my listening room is full of static electricity. Since cleaning records on the VPI, I have no more issues with static pops and clicks. What a huge difference. I also made a batch of home brew cleaner for about $5 a gallon and it works as good as the MoFi that came with it, which is $80/gallon. There a several recipes for home brew on AK. I use the VPI brush that came with it and don't have any issues with it at all.
As mentioned earlier, the directions state that the tank should be emptied every 6 records, but I cannot see why that is imperative. I cleaned over 40 before I emptied it the first time and there was probably about 5 or 6 ounces drained.
Hello,
If I perhaps made mention earlier in this thread, about suggesting the emptying of the resovoir every 6 records or so, this was just so a new user will get the feel after some experience with the machine, and will then better know what to expect.
One may be able to clean 20, 30, or even like you have, 40 records without feeling the need. But read on, and read what I'll say in the next paragraphs.
The VPI's machines, just like many other machines is in essence just like a wet-dry shop vac, or a carpet steaming machine, in that it has a baffled resovoir to restrict fluid intrusion into the vacuum motor, which BTW isn't waterproof.
Unlike some more sophisticated, and costly machines, the 16.5 does not possess any means of warning the user of a resovoir that is full, or nearing full. In any case, the Ametek-Lamb Vacuum Motor inside will still be subjected to aresols-mists from the vacuum, and while it can tolerate some slight periodic misting, and then let dry, it cannot tolerate much more fluids than this.
So, with that said, I myself would rather empty the machine more often, than not enough. This motor is expensive and if it fails due to water intrusion, this is one aspect of your warrantee that VPI may refuse to honor.
Besides it being wise, I also find it's good to take an occasional break from a cleaning run to empty the machine, and another plus, is that it gives those 16.5 owners who have not installed a cooling fan on their machine, a chance for the motors to cool down a bit.
And it is another reason why VPI strongly warns against ever tipping the machine, or moving it while it has fluids in the resovoir. Tip the machine to the left, and all those fluids can bypass the baffle, and go directly into the vacuum motor.
It is permissable, and even a good idea I have found to carefully slightly tip the machine rearward when draining the tank, that you will get more fluids from the tank this way.
The drain nipple, and drain hose is located at the rear of the tank, which is facing the rear of the machine.
And I think I mentioned before, after a cleaning run, do insure you have emptied the resovoir tank completely , and I always clean the wand, and leave the vacuum wand off the machine for a good period, thus letting the innards of the machine, and any internals of the vacuum motor fully dry.
It will help insure you'll get many years of life from that motor.
Hope this helps. Mark
