JVC a_k22 restoration
adelo
Hi to all! I started restoring an old amplifier (JVC a_k22). Could someone help me with the specifications of the thermistors I have highlighted?
Carefully remove the one that is not broken. Let it come to room temp after desoldering. Measure the resistance. Put your soldering iron CLOSE to the thermistor, if its a PTC resistance will rise. NTC - the resistance will reduce. Carefully dip the thermistor in hot water (85C - 100C) and measure resistance. Post the temperature and resistance values.
Hello! I return to the above topic
After measuring the thermistor at room temperature I found 2.4 kohm.
After heating it to about 80 degrees celsius then I measured 100 ohm.
Based on the above, what should I choose for replacement?
