Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
A most excellent looking pair of The Advent Loudspeaker in walnut. We call the OLA but you can see we added the original to the name. Advent didn't use that word in the name.
The OP's pictures show an OLA with a walnut veneer cabinet. I have a similar pair in my garage.
Only the NLA came in a bullnose cabinet. Unfortunately, many call the OLA cabinet bullnose, even though it has a beveled front. There never has been an OLA with a bullnose cabinet. Bullnose refers to an edge or trim piece that is rounded. A bevel edge or trim piece, like on the OLA, has a flat surface that is at an angle to the other surfaces.
Only the NLA came in a bullnose cabinet. Unfortunately, many call the OLA cabinet bullnose, even though it has a beveled front. There never has been an OLA with a bullnose cabinet. Bullnose refers to an edge or trim piece that is rounded. A bevel edge or trim piece has a flat surface that is at an angle to the other surfaces.
I complained to a mod about the fact that the Advent model determination thread called these early chamfered boxes bullnose and the thread was corrected since the OP is no longer on AK. There was only that one correction and some of the pics might still be mis-labeled but this is the source of the bad info calling this speaker the bullnose. Once it is on the web, it is the truth and it will not die out.
Remember we call it the OLA, not Advent, they called it The Advent Loudspeaker.
Somebody stuck the wrong label on the back of that one speaker. The one that has "Utility cabinet" on it.
I can't make out the serial number on the one but it looks like it may have only 5 digits, which would make it having been manufactured in the very early seventies. The "A 247420" was made later, sometime in 1976, June-July?
I too have a set just like them in my garage - sitting. Not bad speakers and the cabinets are near mint and they are fully functional, but... My KLH Sixes beat them and are in primary rotation instead. Serial not 122618 and 122631.
These were built in the mid-70's. If the caps have not been replaced, you will want to consider doing that as well as replacing the surrounds. Note that there are at least 3 different versions of the crossover.
OK, cool. Very close, then. Not that it matters that much. I have a pair of very early Advents (1970) and several later ones (1975-76) and they pretty much all sound the same, even with the different crossover versions.
These were built in the mid-70's. If the caps have been replaced, you will want to consider doing that as well as replacing the surrounds. Note that there are at least 3 different version of the crossover.
