Ghostberry, you might want to take some pictures outside and inside of the binding posts, that will show how they are secured or attached to the mounting panel. Usually, they are separate pieces that are mounted via screw threading on the posts and large opening nuts on the back side. Remember that they are soldered to a speaker or ground wire so even if you somehow turn them and they come loose, the wire needs to be cut and resoldered to the new post. You also have to see if there are individual holes for each post or a slot and mounting piece internally that holds the binding posts.
Since your unit is not a Yamaha but a Nikko Alpha II, you might want to start a new thread in Solid State forum where others with experience with Nikko products might be able to chime in.
