The DSBG is on the front vertically mounted power circuit board where you can't easily spot the issue. You should also have the .22uf X2 cap on the Control 1 power supply board looked after.
I'm still trying to decide if the M-70 or M-80 has the worst binding posts ever...It's a shame as they are all such nice sounding amps.
( DSBG) Damn SONY Bond Glue. A lot of japanese manufactures and others. Used a glue to fasten down larger components such as heatsinks and large capacitors. By now the glue is all or mostly crusty dark brown/black. It attracts and retains moisture. If it is in contact with jumper wires or component leads it will eventually oxidize the leads/jumpers to the point of failure.Best to eradicate the stuff...What do you make of the statement of Sony adhesive failure? What exactly is this referring to?
No it is not heatsink compound...
May be a good idea to research the benefit of using higher uF caps in a power supply, Mundorf absolute quality and the high end parts supplier of Parts Connexion.I would prefere parts avalible at mouser, if anyone can send a link for suitable 10000µF and 18000µF replacement i would be greatfull.
