local weed growing discussions
There are a couple dark sky sites in MI. I hope to spend a spring night out at Port Crescent one of these years.
Hard to see the 94 glow from all the local illumination. Detroit is bright, the local suburbs hardly less so.
There's a couple dark sky sites in MI. I hope to spend a spring night out at Port Crescent one of these years.
I found out about it when we visited Flagstaff in 2017--we went to the Lowell Observatory and had a tour with someone who told us about it. I noticed it on a later visit that year where even though Flagstaff isn't exactly a small town, being a Dark Sky city really made a difference and the sky was still dark despite being in a busy Target parking lot in a commercial area. We attempted to do some stargazing at Arches last summer (since the point we visited was a Dark Sky area), but had cloud cover and lighting off in the distance. I want to get back to Death Valley again as well, as the night sky viewing there is supposed to be one of the best.
I sleep with 1.50" foam insulation blocks in the windows, to block out the lights. And I live out in the boonies. No disagreement.
I'd be afraid to do that--I'd probably hibernate all winter. :D
Lot less light pollution out west. For a few more years at least. Even the dark sky area in MI are really only dark comparatively speaking about the illuminated areas..
Pitch black here, no lights what so ever, but it's also cloudy about 9 days out of 10 so not much to see in the sky. But on those clear nights, it's pretty cool seeing the aurora, or when it's really clear, our own galaxy! Makes you want to drag out the Ole telescope and be humbled by existence..
Honestly I am getting tired of the commercial side of this. I miss organic homegrown of yore.
Try some more seeds outside this summer. You can pick up feminized seeds (dosed with cytokines) that will will only flower fem, clones, or start regular seeds @ around double the plants you want to flower and approx 1/2 will be female.
You can even get some really good results from bag weed seeds, if those even show up any more.
Yeah man I'm seriously considering it. Got two areas to grow in. Out back is north facing and down hill. In front is all day hot sun but publicly viewed.
My backyard veggie box has been a challenge due to cats, bugs and mildew. Biggest concern growing in back is the mildew. Fence line gets earliest peak of sun and is where box is on right in pic.
Front could produce 10' tall trees of bud however I do live in Oakland. Albeit in a pretty high rent area but a locked front gate only goes so far.
Could you recommend good budget friendly options for seeds? Being a noob, spending a $100 or more on *fancy seeds seems foolish. Then again I don't want to waste effort on schwag either.
Just got some 'magic beans' from Barcelona.
Chocolate Haze - 90% Sativa from Royal Queen
Jack Herer - 80% Sativa and 20% Indica
also got some freebies, OG Kush and White Widow.
Supposedly the Chocolate Haze will grow to enormous size if left to it's own devices. Pics in November.
(grin)
Magic beans, I like that line. I'm trying something different this year. Put some seeds in dirt a few days ago to give them a head start. My best friend gave me a couple of LED "red & blue" lights to try out. The thing I'm a bit discouraged by is they give off no heat and my shop/music room sits at around 40F without my stove going, Not sure they're gonna sprout at those low temps. If they don't go I'll just have to wait for spring to start like in years past.
You could set up a heat lamp or an 100w incandescent bulb in the shop to keep it a bit warmer. 40 degrees sounds too cold to me.
I'm going to spend part of my day in the shop polishing a TT dust cover or two, the temp outside is about 14F and it was 34F inside before I lit the wood stove. I don't think this LED red blue thing is gonna work for me. Maybe time to break out the big boy 1000 watter. ;)
The warmer the temps, the better the germ rates up to about 80-85F. Or was it 90-95F? Light doesn't matter until they sprout. Like elcoholic mentioned you can use heat mats under the tray. Mine start off in a 4x2x2 foot enclosure with 2 T8 4' fluoro lamps. I turn off the exhaust fans and they're enough to keep the temp nice and balmy. I do the same for rooting clones too. If it's winter time I put down a 1/2" piece of styrofoam to keep the medium toasty.
I never put mine under a 1K until they were at least a foot tall, back when I had one. Bright light with limited root space is tricky.
Does anybody “bottom heat” their plants with heat tracing? I remember that being a thing back in the 70s
I've done it, for seeds and clones, but my setup is geared towards efficiency so I've found ways to do without, as I mentioned above. I have lifted the pots off the floor, since I have an unheated crawl space, onto some 2L Pepsi flats I found in the trash for the months of Jan/Feb and pump the heat from my CMH lamps along the floor underneath them.
I understand aquarium heater use is common with hydro growers but I've never messed with that.
Problem solved, brought them in the house. We have an old beat up wall unit that's stuffed in the corner of the living room that's going out in the spring, free to whoever or to the dump I don't care. My little starter pots sit quite nicely there for now and they'll get the warmth they need. This room was always kinda dark anyway. :) Just strung the light from a couple ceiling hooks and called it good.
Thanks everyone for your suggestions.:smoke:
Update, the seeds really like the house warmth, they're popping up fast and furious now. I was worried that the cold in the shop may have killed them. ;) I had my problems last year by accidently killing most of my babies early, this year will be a good one. :)
