sqlsavior
Lunatic Member
Must be private enterprise!Why does my water boil faster when I am working in Scotland than it does at home in North Carolina![]()
Yes, the last time it approached (as I recall) $3/gal average in the US. As soon as prices hit a level that affects consumer spending, strategic reserves are released. This shouldn't be news, or shocking (or even political). It's just one of the reasons that US prices stay where they do. They are effectively controlled to stay there. Ultimately this affects what the US consumer will purchase for a vehicle. And why not? There's not too much penalty for driving a pickup that gets 16mpg compared to the rest of the world.
3000 watt kettle.Why does my water boil faster when I am working in Scotland than it does at home in North Carolina![]()
That's not how it works. A 240 volt supply doesn't make appliances consume twice the energy of a 120 volt supply.
Hot Ovaltine?
Actually, it sounds like what a certain grumpy someone needs is a big hug.![]()
Yes and as such burns more electricity as more watts are needed, thanks for arguing my point.
You mean '240 volts' here.will take twice as long to heat a given area vs the one on 120 volts.
Yup, I did! I changed it while you were posting, I think. The good thing is that somebody caught it, which means they understood the point being made!You mean '240 volts' here.![]()
Yes - you're not buying power. You're buying energy. A gallon of gas is about 33 kilowatt hours.I'm curious if some know how electricity / electrical consumption is measured. Just think of your power bill; it's measured in kilowatt hours. Note the time component.
And speaking only for myself, "some" occasionally carelessly interchange power and energy, despite knowing better.Some don't seem to understand the distinction between power and energy, or the simple relationship energy = power * time.
I think you're associating the wrong cause and effect. Pricing averages $2.847 today. What was different then was a spike in production that led to record breaking levels. We simply didn't need that much.Yes, the last time it approached (as I recall) $3/gal average in the US.
To be fair Germans engineers are the 2nd best in the world!![]()
And some where keeping Dave busy chasing his tail.As I said earlier, I fear some don't appear to understand electricity at all...
Some people find that a power conditioning unit is useful when they have power that is so "dirty" it can't be adequately cleaned by the amplifier's transformer electronics. But providing the power cord is properly rated for the use and has no faults (and doesn't require additional screening, as discussed above), I can't see how it could be degrading the quality over 1m given the variation over the miles of cable and many junctions it's passed through.
And again, if someone can demonstrate to me that power cable quality can affect the sound, I'm open to change. (Just like I recall audio cable demonstrations (eg. interconnect and speaker cable) demonstrated that different quality audio carriers do influence the sound.
Ok then; my 2 pence; 1st pic shows about the average emi distortion on my home electric lines at 9:30pm where it tends to run a little higher than it does during the day. Second reading is from a dedicated audio line using spiral wound multi strand wiring as opposed to standard solid core wiring. Last pic is the reading I get from my preamp's extra outlet after it passes through a balanced Furman conditioner.
I have what I consider to be decent power with zero problems. But as the meter shows everything matters and yes the reduction of emi from 600 down to 42 is audible.
And most likely, the source(s) of the noise are in your home!But as the meter shows everything matters and yes the reduction of emi from 600 down to 42 is audible.
Possible but more than likely not. These reading were taken with nothing running on the noisiest circuit which has solid core wire and it doesn't make any difference in the readings if something noisy is running on a nearby circuit. Led dimmers and newer fluorescent fixtures are terribly noisy and they were all shut off. 5-600 is average line noise on solid core line while I've never seen over 125 on the 3 circuits that have multistrand wires. This tells me the wiring is making the improvement, Normally I get my lowest readings during the middle of the day which I think may be due to the power provider switching to cleaner form of power; possibly solar.And most likely, the source(s) of the noise are in your home!
No doubt. If your audio system has any digital components, you have a powerful local source of RFI.This tells me the wiring is making the improvement,
Big sources of electrical noise are household WiFi (sometimes from other households), cheap LED lighting (good ones are not noisy), and mobile/cell phones and their chargers.Possible but more than likely not.
