MC2105 auto former
I read the description of the amp and it says that it’s already been stripped of many parts and the only guidance as to whether it has what I need still is to look at the photos. I’m not experienced enough to identify whether there is an autoformer on it still. If there is, I will most certainly buy it.
Bid as high as you can go. It likely will go cheap, but maybe not.
Can the casing of the autoformer be swapped (for appearance purposes) if desired?
I think the aluminum 'decals' are available, through a 3rd party site.
The exterior can be refinished with black Appliance paint, which (I believe) is Epoxy based, and rock hard, when it dries.
Love it. Thanks
I didn't see that particular decal on the 'Bay, (BTW, 2100/2105 Transformer Decals are identical) but there were decals for other Mcintosh models. You can always inquire, to see if a set can be fabricated. Since the decal (label) is aluminum, chances are, it will clean up to a satisfactory state.
I’ve just zoomed into the photos and it does have an autoformer. I’m not experienced at winning eBay auctions but I’ll take an aggressive run at it
wait until last few seconds, then give your maximum possible bid. In that way no one else would increase your bid but you will buy for last max mid+some increment. Of course this require some practice.
You can try small test bids to check system response delay to gauge your "snipe bid" timing, if that still works. Make the sincere final bid high enough in time that a similar late strategy by others won't lose your chance.
My two cents with the bidding.
As the last parts unit sold for $480.00 plus shipping.
The folks that lost out on it, could be more than likely eyeing in on this one.
So they may be thinking the 500 range.
You may have to go that high, best to go high than to lose out. But not knowing also what you are willing to spend.
Pre load your bid and click on your bid with 4 to 5 seconds left on auction.
Also you could sell the other autoformer and other parts to regain some of your money back.
