So with further research, I have come across some other interesting ideas for powering a tube amp with SMPS's.
This looks like the closest to what I really have in mind:
This is from an eBay vendor (no affiliation, no knowledge of, or dealings with this seller.)
It may look like a regular switching power supply, but it has a DC200V-520V (customize by the manufacturer, not adjustable) output.
It also has a (-) bias output (adjustable) and several outputs for heaters and DC aux outputs.
The vendor claims 300W-400W continuous and "1000W power generated during dynamic signal impact, less than 100 megaseconds" (so as long as that bass riff lasts less than 3 years, you'll be fine).
The vendor doesn't specifically state the current rating of the HV output, but he mentions "KT88" in the auction title. So one must assume they are not talking about a flea power amp or pre-amp.
Unfortunately, it is expensive ($140), and set up for 220VAC input. Perhaps both are "customizable".
I should also not that the basics (transformer, rectifier, misc parts) will cost at least as much for a conventional power amp power supply.
It certainly looks like someone else is thinking along the same lines as I am.
They are also thinking the same thing over in Russia:
http://www.klausmobile.narod.ru/projects/pr_05_carpower_e.htm
(Second schematic is the SMPS plate supply)
Here is a 12V input, 250V @ 300ma output step-up switcher.
From my research, this has a number of features that are essential for an adequately efficient, noise-free plate supply SMPS:
- Push-Pull transformer drivers
- Full wave or bridge rectification on the output side.
- True isolation, including the Opto isolated feedback (As typical for "normal" or down SMPS's)
- Good filtering of the output.
Note that he even made his own transformer.
Another Approach:
I also keep seeing these pop up in my eBay searches:
These are the inverter section only. In other words, the output is the high frequency AC right from the secondary of the transformer. A rectifier and capacitor(s) should produce clean DC. It wouldn't technically be regulated, but of course classic tube amplifier power supplies aren't regulated at all. Different taps and different diode arrangements should result in a wide variety of available voltages.
Edit: Input is 12VDC.
Apparently the switching frequency is around 20KHz. Ideally it would be higher to stay well clear of the audio band. Fast diodes of sufficient ratings would be needed for the rectifier.
These are available in different layouts, and with or without heat sinks included. There is also a 500W version with 4 driver transistors.
