ron-c
Addicted Member
You need one!I want one....
Yes, yes I do!!You need one!
Too long ago....it must be time!!When was the last time you upgraded Kev? I think it's been a while....
I have seen this before. Sounds like the IEC power cord was not fully seated. If it is not pushed all the way in on your C48 then the standby power will light up but there will not be sufficient current to turn on the main power supply. I doubt there is anything wrong with the C48 but you can still buy a C52 if you want.
Thanks,
Ron-C
Hold the press's! What the heck, I'm sitting here and suddenly the amp turns itself off and the C48 and MR88 are still on? I don't think those two went off at all. I just turned the amp knob off and back on. It came on, but what the heck? The house lights didn't blink or go off. My PC didn't have a problem. lol, apparently the ghosts in my house don't like McIntosh. Geezs, what next?!
OK, I just did an interruption of power, on purpose. The amp comes back on the preamp and the radio do not. I wonder what happen when the amp went dead on it's own?
I'm very much sold on the C52......Looks like the C52 is a mature digital product too. Solving all the initial comments about USB and/or digital locking up.
I was all C1100 up to this point, but a Phono stage,DAC,EQ, and Preamp in one box is so simple!
My MC452 has never powered off without signal going into it, but I do use the remote power control....
This thread is way off topic now, perhaps exhippy should start his own thread....
I believe the MC452 will power off after maybe 30 mins if there's no signal going in, but a 'Power Control' cable running from the C48 to the 452 will keep it on. Was there music playing when the 452 shut down, and do you have a Power Control cable between pre and power?
Hahaha, its not that serious.....We can't have a man down with his 452!!I'll risk replying considering my ***** are on the chopping block. It was in use at the time with the MR88 running. It just did it again, hours later, cold. No power control cable between. If you want to reply better do the inbox thing. I wouldn't want be responsible for a mutiny. Walking the plank sucks.
I think you should check your power cables into the 452 and the 48, it easy for them to not seat properly and cause these sort of intermittent problems, the one on my MEN is a bit touchy, if I get behind there with my big arm and accidentally brush against it, the MEN will shut down on me......gotta make sure they're pushed right in.....
Power Control cables will keep the Mc452 powered on as it relies on the PC signal from the preamp to keep it on after 30 minutes.
Thanks,
Ron-C
