Back to my restoration... I started on the tonearm tonight. The wires disintegrated when I tried to disconnect the pickering cartridge so I ordered some kab superflex tonearm wire. The arm was full of spray foam or something which had to be removed. I'm a little worried it will change the damping or balance but didnt see a choice. Once clear it was pretty easy to pull through the new wire. I debated whether I should twist them or braid them but the wire is so flexy it wouldnt hold a twist. I decided to try them loose. Leaving the solder work for a clear head tomorrow.
