An actual budget number or range may help here as well as some indication of your needs (MM only or MM/MC would be a start). For some on here, "not-break-the-bank" may mean something completely different than what it does to you. Agree with the post to do some searches, there are lots of threads including ones dedicated to the ArtDJ as well as the Emotiva XPS-1, among others. Good luck in your search, I am in the process of moving up the chain a little bit in this area as well. Lots of choices in most any budget category.
PS - the headphone jack requirement is one that I just noticed, this certainly should narrow the field a bit.
