Surrounds a new adhesive? A little long winded
I must start out by saying, I have little previous experience using other "surround" adhesives, so I can only relate my findings to this one.
The drivers were by all accounts going to be somewhat difficult to deal with, EV 15 inch woofers from the Sentry III,s.
I won,t get into the whole story regarding obtaining the actual surrounds, but let,s just say I would not be able to replace the ones I had if I screwed it up.
I have used many types of adhesives in other applications,
so I read the posts and looked at the various products recommended in stores when possible, ie drying time, consistency, flexibility, color, and just what it was made of.
I ended up buying a Permatex product, id #25832 marketed as an automotive
general purpose adhesive. Pit Crews Choice.
This is what I found.
consistency: is similar to tooth paste, does not run.
initial tack time: 5 min depending on temp. Note this is prior to contact being made, both surfaces must be coated.
level of initial tack/bond: high
ability to shift both surfaces once bonded, but prior to full cure: excellent
total cure time: stated as 24 hours, seemed usable at several hours but I waited specified time.
flexibility after curing: good
color: semi transparent
Due to the consistency stated above, spreading the product out with a small
implement or brush is required.
Overall this product worked well for me, particularly in the high level of initial tack, yet the ability to be shifted if needed, at 10 minutes after contact product can be separated with no visual damage to foam or cone, This may vary with temp and materials used.
I will use this again.
