OMI
I have been using a combination of Aleene's Tacky Glue and Power Poxy contact cement.
http://www.powerpoxy.com/productDetail.asp?productID=461
"Cures and can be handled in about 1 hour, Full cure overnight,
Color: Ultra-Clear, Bond strength 4000 Lbs., Hardness: Rigid,
Waterproof: Yes, Flammable: No, Temp Range: -30F to 180F"
http://www.powerpoxy.com/index2.html
I had ordered a surround kit a long time back (I think from Simply Speakers) and they had sent 2 tubes of Power Poxy STIX-ON CONTACT as the glue. Works GREAT but you better get it right the first time as set time was less then a minute... I needed some more as I had 3 sets of woofers to reform and Wal-Mart was where I got the Power Poxy last time... None this time... Looked at the Power Poxy web site to see where else I might find it and they had a new line... and product.. SUPER CEMENT... Found it at Walgreen’s Drug Store….
"Cures and can be handled in about 6 hours, Full cure overnight,
Color: Crystal Clear, Bond strength 4000 Lbs., Hardness: Flexible,
Waterproof: Yes, Flammable: No (when dry), Temp Range: -30F to 250F"
http://www.powerpoxy.com/productDetail.asp?productID=464
This NEW stuff has about a 5 minute work time before it reeeeealy starts to hold so you have time to work any glitches out. The contact cement works great also, but you have almost zero time to work glitches out.
On my last set of speakers I got the hang of it with the SUPER CEMENT.... Trick was to place the glue and spread / level it out and not to use a lot...
You all might give it a try... The SUPER CEMENT....
