rudkinst, I'll looking for a source of that 1S188 diode. Where are you located?
Whitby, near Toronto. Sayal electronics is my go to.
Put on the brakes, I was looking at the wrong part in the parts list. That diode that seems to be bad is a "KB-269".
BZX75/C1V4 looks to be the best match, but as you say, that one seems to be unobtainium too.BZX75/C2V1
Resistors are non-polar. You are working only one channel. A diode has an anode and a cathode.
You want to connect two diodes in series with the cathode of the first soldered to the anode of the second. Keep the distance between the first and second to a reasonable length, but you do not want to over stress the leads and physically break the diodes. Carefully desolder and remove D601 and put this diode pair in it's place. Then on the other end of the purple wire, lift it from the board, and install the 100 ohm resistor between the board and the wire.
Let's leave the shunt resistor across VR606 off for now, and take some measurements. Turn VR606 fully CCW. Done
Measure the voltage from point A to chassis ground says 1
Measure the voltage from point B to chassis ground says 1
Measure the voltage between point A and the emitter of TR605. Says 1691 at 2v.
Then a picture or two of your work may be helpful.
One other thing. After making the above measurements, set VR606 to about 75% of its CW rotation and remeasure the voltage between point A and the emitter of TR605.
At 2v it measures 1
With VR606 fully CCW,
Set VR606 to about 75% of its CW rotation and remeasure the voltage between point A and the emitter of TR605
Good believable numbers, but too low. I though that might be the case - please change the 100 ohm resistor to 470 ohms (yellow-violet-brown) and repeat the measurements. I'm looking for the point 'A' to TR604 emitter voltage to be less than 1.9 volts with the pot fully CCW, and around 2 with the pot about 75%.
