Are there plans/blueprints for the 3 tier design in this thread somewhere?
duh on me. literally 1st post has those plans
I have been looking/thinking for something like this for quite some time and found this thread. Big thanks to the OP. I have just finished mine and am pretty happy with it. I copied the version from BionicKoala (thanks !) but left out the dividers. Will see how it goes, for now..I can always easily add something if needed. View attachment 2630830
Used MDF and bought a kreg tool which was a godsend. Paint was what I had lying around and I particularly like the look of the red back panel. There is an old 7" single on the front and for a bit of bling, the 'spindle' is actually a push button switch for the LED strip lights (which I didnt stick on straight... oops)
I joined the forum so that I could thank and share.
Thanks for the inspiration and experience!
Great! Looks just like my first build!I have been looking/thinking for something like this for quite some time and found this thread. Big thanks to the OP. I have just finished mine and am pretty happy with it. I copied the version from BionicKoala (thanks !) but left out the dividers. Will see how it goes, for now..I can always easily add something if needed. View attachment 2630830
I have no idea as it's a picture I found on the internetLooks great! What are the measurements?
Can any of you show me what you've done for lighting? Specifically, under lighting for the lower shelves, LED strips, etc. What did you use, how did you mount them, etc.
I was massively lucky. My Plywood was free from a B&Q DIY store here in the UK. The edges had been damaged so it was offered as 'scrap'. They still cut it down for me in store for Free too. The castors came off a trolley I found in a junkyard/tip. The lamp was made by my daughter in 'Tech' at school. The Wood glue and 2 inch screws I already had. The only cost was the LED lights, anti-slip mats and paint. Probably cost me about 25 quid. what's that? $35?![]()
Hows the visibilty and digability on the bottom shelf when you kneel down to look? Im thinking of building something like this for my shop. Not sure if customers would dig it or if I should go with the 2 shelf version.
I would say my 2 shelf original build was easier to access and view, but it depends on your required capacity. My 3 shelf holds about 1000 albums/12 inches. - In my home environment I would say LED lighting is necessary. I have thought about having the records side-on 'book shelf style' on the bottom would help with 'rummaging'. i've been considering taking out the divider and modifying my bottom shelf. On your topic, In a shop? I do think you'd have to think more about ease of accessibility. I know what's in my collection so I don't really need to 'rummage'.Hows the visibilty and digability on the bottom shelf when you kneel down to look? Im thinking of building something like this for my shop. Not sure if customers would dig it or if I should go with the 2 shelf version.
I made it slightly shallower than the plans at 18" deep. This makes the cabinet conform more to standard depths of most furniture so it doesn't stick out. I used tongue and groove joints on the shelves and the back, and pocket holes on the fronts and dividers. It's extremely strong and I'm happy with the results, I just wish plywood wasn't so expensive these days.
FWIW... I've got an LPBIN1 from LPBin.com. It's dimensions are 22" deep by 28.5" wide by 44.5' tall. I can tell you that 500 LP's is as many records as I am able to fit in it. Of those 500 LPs there are 36 double albums and 2 triple albums. Not sure how many of the singles have gatefold covers.Now I need to figure out how many records the bin holds and get to work on 2-3 more so I can store my entire collection.
