Rega Owner's Thread
As above I have the Elys (1) on my planar 3, but I'm curious to see what youfolks are running and what cartridges are your favs for your Regas. So what stylus is your favourite to run on your Rega?
P3 24 with a Denon DL 110. I think it's a great sounding cartridge on the Rega, especially for the cost.
I've also used a Dynavector 10x5 and really liked it with the Rega.
I just sold my Planar 2 a week or so ago, although I still have two (nominally) Rega tonearms on my Notts - an OL-1 and an AudioMods Series V.
-D
Just bought an old RP3 and had it serviced plus added some after market kits to pamper her after years of neglect by previous owners.
Has had a fascination with Rega Planar 3 since aeons ago.
The name just strikes a chord deep inside my heart...Finally I have one.
Noticing that the first post on this section shows an RP-1 with a higher-end Rega cart, that three bolt system to fix the cart in place works on the RP-1? How do you set the stylus overhang, or does the 3-bolt system take that out of the equation? And the counterweight...is there enough travel for the weight so that you can balance the arm?
On the Rega site, it's positioned between the RP-3 and RP-6. I love the gloss white…hmmmm. Been wanting to move back to Rega for a while now!
I have a gloss white RP6...nice!
The new one wasn't even on the site a few days ago.
Rega Carbon RP1: Cartridge Advise
My BIL just bought one and it sounds very flat and lifeless; bassy and no sparkle. He has B&W CM1 speakers and a Carver separates. Even bought a $400 tube phono stage. We tried a Pioneer Rx, same flat sound. Could it be the stock cartridge? Any upgrade ideas if that is the problem?
thx
bob
Well I've been running a 'virtually' stock RP-1 now several months - the only change was to replace the belt with better white one - but I've been so impressed with the lively and vibrant sound, I've forgotten about swapping out the stock Carbon cartridge..!!
MY RP-1 is running into a Rega Fono mini A2D pre-amp, and Yamaha mini system. It sounds as relaxed, or as dynamic and exciting as you might want it, depending on the record being played..... a favourite of mine for listening, and for testing, is actually a mono LP of "The Glenn Miller Soundtrack" on Coral Records, Decca, from around 1970.
Even though it's mono, the RP-1 takes the image and spreads it wide.. and 'up-and-down'.... so that various instruments seem to come from different heights above and below the speakers! And when Loius Armstrong blows his horn it's frighteningly real..!! He's here in my room!! And then Gene Kruppa lets rip with a drum solo and even though it's mono, it just sounds massive and has space - snare and it's symbol seem different to where crash cymbals come from!
It should all come form an even central mass, but with this Rega, it doesn't - it split's it all apart and projects it clearly!
Nothing dull with the RP-1 and it's standard Carbon cartridge...
Other turntables that I've used in the past through this same Yamaha system (including BSR, Pro-Ject, Technics) have come come close to this level of dynamic resolution :)
Just curious, if other turntables "(including BSR, Pro-Ject, Technics) have come come close to this level of dynamic resolution". What made you get a Rega? Sounds like you were plenty happy before?
I got this Rega after trying a Pro-Ject Debut III and not being too happy with it.
The turntables mentioned before were only a small part of what I have owned over the years; they're just the most recent (over the past decade). Back in the early 80's I had a Planar 3/RB-200 which was great, but I foolishly traded it for a supposed upgrade to a Logic DM101, which was a great deck, but a pain in the neck to set-up and use!
So after plenty of faffing-around with various Technics - including a 1210mkII - I decided to go back to something simple and well built, and the Rega fit that requirement and my budget! This RP1 just recalls everything that I loved about the old Planar 3 all those years ago.... :)
just got my brass pulley from TangoSpinner. So who here has installed one of these? What's the best way to pull the plastic pulley off if I don't have a puller for it?
