I've had the PEEK Bearing Sleeve since around April this year. I'm happy with it although I freely admit I havent done direct
comparisons as doing so is a bit of a pain in the arse. There seems to be improved detail especially in the lower frequencies.
One note of caution - when I first fitted it, the Groovetracer Sub Platter wouldn't sink into the PEEK Sleeve as it should. I determined
the problem to be the actual spindle hole in the plinth was a bit too tight. So I rubbed the inside of the spindle hole down slightly
with a piece of fine sandpaper until the PEEK Sleeve dropped in easier. The Sub Platter then dropped down slowly into the sleeve
as it should. Job done.
My deck also sits on a custom made wooden frame that has adjustable legs.
This is the Michael Lim Motor Isolation Base as I was fitting it. He designed it for the Rega Premotec Motors so I had to change
some of the parts used in it to fit it to my deck, namely the hex spacers. The GT Ref Sub Platter can be seen in the background.
This is the motor in position via the Michael Lim Isolation Base. The black bolts are loosely finger screwed into the top hex spacers
to simply act as placeholders - I can tell by their position when the motor is in the right place, they dont even touch the holes in
the plinth. The increased hole in the plinth is the result of the Origin Live motor kit not functioning as it should've in the past - I had
to increase the hole and force the position of the motor back as far as I could in order to get it to run slow enough. As I mentioned
already, the kit has worked fine for the last two years.
And, for the last few years I've been using the AT450E cartridge I bought back in 1993. I have a variety of stylii to use with it, and
there's still quite a few more I've got to try and get my hands on yet...
James H
