StimpyWan
Addicted Member
They are at it again...
Gjallarhorn Amp
Stereo, 8 Ohms: 10W RMS per channel
Stereo, 4 Ohms: 15W RMS per channel
Mono, 8 ohms: 30W RMS
Fully discrete, current feedback topology is amazingly fast (-3dB above 1MHz before input filter) and measures well, especially for such a simple stage.
2 pairs of 10A output transistors per channel, including one pair used for Continuity S stage to provide greater transconductance linearity.
100% DC coupled throughout, no capacitors in the signal path.
Fully linear, all-internal power supply with 80VA toroidal transformer and 30,000uF filter capacitance in the main rails, plus 13,200uF for the boost rails.
Separate discrete regulated boost rails improve efficiency and are ground-referenced (not stacked) to ensure each channel’s performance is independent from the other.
Analog protection system uses a “least invasive methodology”—no active devices in signal path, no current limiting, no crowbars—just current and thermal sensor and DC servo.
4-layer PC board for optimal layout and current flow.
No fan.
Gjallarhorn will run 4 ohm speakers in mono just fine—up to a point. At which point, the over-current or over-thermal protection will kick in and your fun will end. That point is about 30W output, just like into 8 ohms. So not very exciting. If you need a ton more power, there’s always Vidar.
https://www.schiit.com/products/gjallarhorn
You missed the new baby amp.
Rekkr
Power Output:
Stereo, 8 Ohms: 2W RMS per channel
Stereo, 4 Ohms: 3W RMS per channel
Mono, 8 ohms: 4W RMS
Frequency Response: 20Hz-20Khz, +/-0.01db, 3Hz-500KHz, +/-3dB
THD: <0.001%, 20Hz-20KHz, at 1V RMS into 8 ohms
IMD: <0.001%, CCIR, at 1V RMS into 8 ohms
SNR: >120dB, A-weighted, referenced to full output
Damping Factor: >100 into 8 ohms, 20-20kHz
Gain: 4 (12dB)
Input Sensitivity: AKA Rated Output (Vrms)/Rated Gain. Or, 4/4. You do the math.
Input Impedance: 20k ohms SE
Crosstalk: >80dB, 20-20kHz
Inputs: L/R RCA jacks for stereo input, switch for mono input on R jack
Topology: fully discrete, fully complementary current feedback, no capacitors in the signal path
Oversight: over-current and over-temperature sensors with relay shut-down for faults
Power Supply: 6VAC, 2A wall-wart, 12,000uF filter capacitance, plus boosted, regulated supply to input, voltage gain and driver stages
Power Consumption: 12W maximum
Size: 5” x 3.5” x 1.25”
Weight: 1 lbs
