SL-220 on the Bench..
Those are nice entry tables. Pretty much trouble free and quiet. While they're no 1200, or even SL-D2 (or B2), they perform well.
Was that headshell a bonus?
I have one that no matter how much I Deoxit the speed adjusting pot you can sit and watch the timing marks moving. On the other hand it never has any problems with the auto return function.
I went through that whole De-Oxit/Speed Pot torture with my SL-23. I even took the pots apart to clean them and wound up right back where I started. Tried the thin belt, no good. Tried the fat belt; better but still unstable. Changed the capacitors on the circuit board (THAT was a hassle), still no joy.
Finally I removed the spindle and the minute I looked at it I knew I was on to something. I cleaned all of the old, coagulated grease off of it (and I mean ALL of it, as in ALL of it; you need to get it out of the bearing as well), gave it a quick polish with a Scotch Brite Pad, lubed the bearing by filling it with Singer Sewing Machine Oil, reassembled her and there it was; perfect speed bliss.
That thing has been rock solid for 6 months since; you might want to try that if you haven't already.
Dirty 33/45 switches will cause the same symptoms and problems as dirty speed pots. Clean 'em all.
Regarding the bearing lube on the SL-23. I used a German supermarket brand engine oil on mine and the platter spun for over 3 minutes when spinning it by hand. NOW THAT'S GOOD OIL!:D
Personally, I would not use 3-in-1. But......I suppose it's up to the owner of the deck as to which oil he/she uses to lube the bearing and what THEY are happy with. There are many differing opinions on types of oil.
