Thank you Sir. I enjoy restoring things, not just old radios.Nice methodical work @rhodus. I have a 1250 that I restored but nothing like the undertaking you are doin.
Thank you! I have all the molex connectors I need. Yes, I'm sure several wires will need extending and I will solder the ones that were previously wrapped, like I did on a recent Spec2 rebuild. I will also solder all the chassis ground connections. I think the biggest challenge coming for me is the tuner section. I'll have to locate the equipment needed to do the alignment or take it to a local shop when I get to that point.....
I do not usually use the popcorn, but for this thread I will, since it is an unusual challenge for an AK member. I too am wondering of your solutions for connections. You have wire wraps and those obsolete connectors to solve. Looks as if the original wires were chopped short, they did not leave much wire slack when they first wired them up, so I am thinking many wires may need to be extended, esp. if you plan to use the original hangers.
Might want to trade in that pin nailer for a pneumatic w/w tool
Good Luck
Rick
I assume you are referring to the pushbutton switches. I have experimented with a couple of those and have not been successful. It is extremely difficult to not damage the contact plates during cleaning and reassembly. The slightest bend or kink and that's it, switch ruined. I've been carefully removing the top only, and saturating the inside with deoxit gold in a jar. So far so good.In a pinch, I have stuck a thin jewelers screw driver in the housings to detract the locking tabs to remove the contacts. Finding the correct diameter extraction tool might be an issue unless you have a wide selection of them to choose from. I guess I could try it out again on that one since I have a few of those old connectors in the parts bin. They are crap connectors as it is, no locking/retention means, silver contacts that oxidize and become high resistance, I see glue on many of them because the come loose. I had a 1250 in for service, it would not bias, it was those damn connectors oxidized, crap I say, another Achilles heal in that model, same goes for those damn switches too. The not so holy grail receiver imo.
I was going to mention those switches to the OP, you might want to take them all apart and clean all the crap out of them, it is a big job, a perfect COVID-19 projectI have an stock 950 with the same problem, deoxit is a band-aid fix.
There they are!! No problem dude...when I gave you those things I had no idea I would be doing this project. In fact, I've completed several projects since then. Very glad to hear you still have your 1250 and enjoying it!!hi Rhodus,
Nice to see you're still into repairing SX-1250's!
I'm still enyoing the 1250 that I could finish thanks to the parts I got from you very much!
The making of it in this thread: https://audiokarma.org/forums/index.php?threads/i-finally-found-a-sx-1250-but.677841/
Seeing your list of parts you need for your project you gave away too much, I hope you will be able to find everything.
stay healthy!
kind regards, Peter
Do you mean to say that I could send mine to Mark for cleaning?I am referring to every switch in the signal chain use silver plated contacts which oxidize over time and make unreliable connections. It was a bad design choice. Silver contacts are fine for high power, low resistance contacts but for low current signals paths it was the wrong choice. I guess their thinking was, once the contacts oxidize, so badly to affect the signal paths, throw it out in the junk and buy a new one.
MTF reports that he uses his propitiatory chemical mix and ultra-sonic cleans them. Even then, I am sure there are times they are so bad that they need to be disassembled and cleaned properly. I have no experience doing this myself, but member zeb, aka Bob, and some others have mastered it from what they have shown. I know it is a royal PITA. I could probably design a new switch board using a gold plated contact relay fasterThe choice is yours alone, I am just here to follow along and eat my
