I've had several Graco cartridges, and I am far from grumpy. Plus, I've never seen a 6'4" elf haha
Edit - I'd rather be an elf than a troll lol...
In your case, you're BOTH.
Thx for the pics. Grado offers some of the most interesting cartridges on the market IMO. Always nice to see them discussed.Gold 2 and the Opus 3. The Opus has painted coils and much thicker wire
FWIW (which is probably not much....need a new acronym.... FWIWWIPNM), as a jazz musician by full-time trade and part-time small-scale recording engineer, I've always felt the same way about Grado's SR-60 headphones. Inexpensive, and really uncomfortable for long sessions, but the just sound natural. I can get decent quick mixes with them, and also use them for final master checks along with two other speaker systems. They sound more like my most natural sounding speaker system than my other 'phones (Beyerdynamic DT990 and DT990 Pro, 600ohm and 250ohm respectively). The Beyers are incredibly comfortable, and make for enjoyable listening... but somehow seem to "enhance" the sound rather than just reproduce it faithfully like the Grados.I have friends jazz musicians, whenever they hear Grado cartridge in my system they are amazed how realistic the sound of instruments is, with other cartridges not so much. That's the thing with Grado, if you know and value natural sound, and frequency listen to (small scale) live music, you will feel at home with Grado.
I have a statement reference and the Opus 3 even stock the Opus is better, retipped it is far better. What Grado did with the 3 was game changingI have a G1 with an 8MZ and it's not the equal in SQ of the older Reference Platinum so there's that.
I have several Prestige cartridges and when the Maidinator took out the Platinum the 8MZ was purchased thinking it would be a step up, it wasn't.
In my search I found my first NOS Grace cartridge, and as this was going on a Grace arm........ A few Grace later, some LOMC and the Platinum is still waiting for repair.
Whatever makes these wood body Grados so special is what it is, I say let's put a record on whatever we have and enjoy.
How much gain is ideal for the low output version Chris ?I have a statement reference and the Opus 3 even stock the Opus is better, retipped it is far better. What Grado did with the 3 was game changing
Chris
ThanksUnless you have a phono preamp with adjustable gain, suggest you get the high output version.
My DNM is fine on the MM setting for thr low output version, but a friend needed extra gain with his phono pre. 1mv is a bit less than high output mc's, but quite high compared to low output MC's. If you are unsure go high output as it sounds good also.How much gain is ideal for the low output version Chris ?
I'm using a Statement Sonata 3 (1mv output). My phono preamp is an Audio Research Corp (ARC) PH3 which has 54 dB gain.How much gain is ideal for the low output version
They should not be. In my experience when there is hum there is hum high or low output. The only difference will be if thr phono stage is not quiet.Low output version is more sensitive to motor induced hum.
When I added the Music Hall Cruise Control 2.0 to my Thorens TD-160, my Opus3 slight hum completely disappeared! Have the high output Opus3.They should not be. In my experience when there is hum there is hum high or low output. The only difference will be if thr phono stage is not quiet.
Chris
I have Rega P6 and both high and low output wood bodies. There is a huge difference in hum, low output is basically unusable without Humbucker, on high output hum is mostly hidden by vinyl noise (it is audible if needle is up in the air). On low outputs the proportion of stylus induced signal and hum interference is less favorable, the hum is less masked by the output.They should not be. In my experience when there is hum there is hum high or low output. The only difference will be if thr phono stage is not quiet.
Chris
It's not such a big issue, most turntables are fine. Rega's with their glass platters (no shielding by platter at all) are problematic, as the motor is also close to the spindle and gets close to the cartridge at the end of the side.Have the Statement Sonata 2 low output, has been used it on 4 different tables and probably 6 arms and at least 3 different preamps without issue….wonder if anyone else has had hum issues?
It’s a fine cartridge and will get sent off for an upgrade when used up…..
VR
Andy
That is very strange, an unshielded low output coil should not pick up more hum than a bigger coil. I wonder of thee is more shielding paint on the high there is no other reason I can think of.I have Rega P6 and both high and low output wood bodies. There is a huge difference in hum, low output is basically unusable without Humbucker, on high output hum is mostly hidden by vinyl noise (it is audible if needle is up in the air). On low outputs the proportion of stylus induced signal and hum interference is less favorable, the hum is less masked by the output.
