Trying a blue belt on my TD-125 ll to hopefully bolster the period between cleanings back to years instead of months since Thorens changed suppliers.
No amount of cleaning as made a difference with my last 3 belts so just in case of contamination I dressed the running surfaces with 400 SC on a stick. The platter was then polished with 4/0 steel wool, green ScotchBrite and “green” electric eraser (safe for vellum). Finally cleaned with isopropyl.
The belt isn’t marked but has an inside which is determined by measuring the width of the loop with the belt hung on a pin or similar. The narrower loop occurs when hung from the inside. 30mm vs. 34mm for mine - within spec.
First test - it jumped up to speed and tracks like a 1:24 slot car. Multiple up/down-shifts and stop/starts without upset.
Don’t ask me to explain this but a new tighter belt takes more + adjustment than the old stretched slipping belt. I just except certain things about accurately spinning 9 pounds with the cross section of linguine is beyond my need to know.
This belt requires 60 hours run-in in addition to correct orientation for maximum W&F performance. I can’t detect any instability so far.
I wasn’t kidding about the electric eraser.
Gave it a thorough wipe down with Adams Interior Detailer and machine polished the platter with Simichrome polish.
