Thorens running slow
glover1962
My Thorens TD 135 has started running a semi tone slow. I have changed the belt however it made no difference. It was running perfectly until a couple of weeks ago. I use it for mono and 78 rpm. Has anyone experienced this ?
Hey there. Welcome to AK!
I got one and I love it but In general the 135 is super duper sensitive and picky about finger prints and fat residue anywhere on the drive belt and idler path. So, if you were not careful, you need to wipe everything with a cloth saturated with IPA. Then...
Do you know that cross in the middle of the speed selection knob? It's actually a speed adjustment control. You should be able to turn that cross both ways. It controls the distance of an iron sled under the stepped pulley from the eddy break magnet and affects speed. If you can't turn it, the iron sled is stuck on frozen grease around the stepped pulley bushing so just clean it up and re-lube it. Allow a few seconds for the speed to adjust. There's a natural delay.
