Trivia: Difference between a bolt and a screw?
What most people call a "bolt" is actually called a "cap screw" in the industry.
What is commonly called a bolt is 1/4" diameter or larger, with a hex head. Allen (internal hex) head are called both bolts and screws.
#12 and smaller, regardless of head type, are generally called screws.
Don't know if that's the politically correct description, but it will save you a lot of time in a hardware store.
No, a bolt needs a threaded retainer, either a a nut or a tapped hole. A screw cuts its own threads as it is driven into the material.
bolt, requiring wrench or rachett
screw, requiring a "screw" driver.
here's a shoe in the works for you. Sheet metal screws. They're self-tapping, and normally have a 1/4" hex head with a flat or phillips cut into them as well. Technically by your description they're both a bolt and a screw.
I wasn't sure of this answer, so I asked the college girl working the checkout at Ace Hardware - "what's the difference between a nail, a screw, and a bolt"?
She said she wasn't sure, as she's never been bolted before.
:D
