where did you set the pots? I assume you installed new onesHere is my almost completed MU150 main board. I am waiting for a side mounted tube socket that is currently in USPS Neverland. But I expect it will be delivered over the next week. Thank you, Brice, for making this replacement circuit board available to us! And thank all of you who helped contribute to this project!
| @Brice the neon bulb 606-A2B is unavailable and I was wondering if this would work in its place https://www.mouser.com/ProductDetail/VCC/A1A?qs=rHu0DOexXLD2XDJrE%2BAsOw== |
thanks for the replyNE-2 90VDC. Should work yes. This is what I used.
I did what you suggested, and found my TR1 transistor was dead. I replaced it and I was almost able to get the meter adjusted to 100% on the first part of the Gm calibration. Using a Fluke 3000 FC DVM, I was able to see a high reading of 0.93 VAC. Once I removed the 1.6K resistor and set the F Signal to zero, I was not able to adjust R21 to go from 0.024 to 0.026 VAC. So I have a little more work to do.I would trace the square signal from the the oscillator to the tube grid.
