2 of my posts were deleted because the moderator said buying/selling is limited to a special area. Do you know what they are referring to? Thanks
| Finished up my MU-150 upgrade this evening. Followed Brice's calibration instructions in this thread. All worked as published. I tested a pile of old receiving tubes I had. All tested fine but two. Those two showed shorts. In the trash can they went. It seems to be showing a little more sensitive than prior to board replacement. What was showing 80% is now showing full scale deflection. I re-checked the calibration, fine. Prior to board replacement, my Gm test was not working at all. Now, all tubes except those I trashed showed good Gm. I had to replace my two pushbutton switches. I used DigiKey parts numbers 2368-54-342-ND and 2368-54-347-ND. These are momentary toggles and work just fine. I did have to make an adapter plate to fit inside the existing cabinet. Thank you Brice for a nice board and project. Alton |
I think I remember doing that, but will have to go back and double check.@dogwan , look @ post #33, page 2, bullet #5.
He suggest setting R35/R35A combo @ 510 ohms.
I am going to go try that now and see what the results are. I’ll check a tube to see the before and after.
Are you looking at just having the board built, installed, and the unit calibrated, or are you looking at a total rebuild/rewire?Anyone know of a mu150 rebuild service out there? Would like to get mine rebuilt with all the upgrades mentioned in this thread, and also calibrated. I just don’t have the time right now and occasionally need to depend on my tube tester…
