Which cartridge?
Never heard the ortofon one but the AT is a decent one, nothing spectacular. What is your budget because I would suggest a RedEd.
The 1219 seems to be a mid-low mass tonearm...
Both of these cartridges would work fine.
The Omega is a little more interesting as it is in fact an OM body with an economy stylus on it.
You can upgrade the stylus with an OM20/30/40 - serious top flight performance starts with the OM30 around $200. The OM20 is very good midrange performance.
Or you can fit a Digitrac SE stylus (same as the OM30 made by ortofon for Digitrac) - for only $80 one of the great bargains! http://www.turntableneedles.com/Digitrac-Needle-SE_p_727.html
(Note - to fit it onto an OM you need to clip off the tiny tab at the back of the cartridge...)
I run an OM-DigitracSE - and it sounds great!
bye for now
David
What's a RedEd?
My budget is a funny story. I would be willing to pay about $50 for one, but I also have a $25 visa gift card, so around $75.
The Red Ed us a budget cartridge available with a nice eliptical stylus.... for $30
http://www.edsaunders.com/reded.htm
Ortofon Omega, or perhaps OM5E - $30 to $50 (all same body - different styli)
http://www.turntableneedles.com/Ortofon-OM5E-Cartridge_p_3859.html
http://www.needledoctor.com/Ortofon-Omega-Phono-Cartridge
Ortofon 320u from speakerbits (between $35 and $50)
http://www.ebay.com.au/itm/Ortofon-...Turntables&hash=item3a67a4a848#ht_1296wt_1139
(Might be a bit high compliance?)
Great value option as it normally retails for $150... (FineLine line contact stylus..)
Audio Technica AT95e - the eliptical version of a budget classic
http://www.turntableneedles.com/Cartridge-AT95E_p_695.html
http://www.lpgear.com/product/LPGAT95E.html
Or with a slightly better eliptical stylus
http://www.lpgear.com/product/LPGAT95SE.html
Also upgradeable with a HyperEliptical (HE) or shibata stylus later on
http://www.turntableneedles.com/NEEDLE-710-DHE_p_3722.html
http://www.turntableneedles.com/-710-Dshibata_p_3721.html
Or if you can stretch the budget a bit, purchase it as a HE cartridge to start off with:
http://www.turntableneedles.com/Cartridge-AT95HE_p_3926.html
http://www.lpgear.com/product/LPGAT95HE.html
http://www.lpgear.com/product/LPGAT95VL.html
Another great option - the Shure M97xE - the damping brush on the front helps to reduce tonearm resonances - and associated intermodulations - a unique and valuable feature
http://www.turntableneedles.com/Cartridge-M97xE-Audiophile_p_701.html
Can also be upgraded with a Jico SAS stylus - expensive but very very good
http://www.turntableneedles.com/JICO-SAS-needle-77x3-Dsas-N97xe-for-Shure-M97xE_p_3953.html
I would also be tempted to consider the other AT budget cartridge family the AT92/AT3xx/AT3478
Same body with various styli... all the way to top of the line HE and Shibata
Pricing starts from the mid $20
http://www.turntableneedles.com/Cartridge-AT92E-wcopy-needle_p_694.html
http://www.lpgear.com/product/LPGATSER03.html
http://www.lpgear.com/product/LPGATSER05.html
And goes up to $100
http://www.turntableneedles.com/Cartridge-AT92E-wShibata-copy-needle_p_3716.html
http://www.lpgear.com/product/LPGATSER05L.html
No lack of options
but I would if possible stretch the budget to a Line Contact / Hyper Eliptical / Shibata stylus.... or at least choose a cartridge where I can later upgrade the stylus to one of these.
The different manufacturers tend towards a different "house sound" - all the above are well respected cartridges.
If I was choosing for myself (and had to limit myself to a single one) I would probably go for the M97xE.... a good eliptical cartridge, and that damping brush can help with a LOT of setup issues.... makes life easier.
And then save up for the SAS stylus....
bye for now
David
I have a Dual 1009 and when I bought it, the seller had put the audio technica cartridge you listed. Although its a good basic cart and extremely affordable, the sound leaves much to be desired. Eventually I just swapped it out with the cart on my old turntable, a shure premier. But in your case, I would go with what others have said above, the Audio technica AT95E. Great cartridge for the money and it will pair nicely with your dual.
What's on there now? I see a lot of 1219s with older AT carts that can sound great with a new stylus.
It has a Realistic R1000 EDT. I've had some sound problems, and I've narrowed it down to either the cartridge or the needle. The needle slides out very easily, sometimes while listening to a record. So, I figured on getting a new cartridge to fix the problem.
The R1000EDT is a nice cartridge, M75 variant, post some pictures of it, maybe all you need is a new stylus.
Here are some pics- 1 on the player, 3 on my desk. Let me know if you need more.
Thanks a lot!:D
Possible to get a closer shot of the stylus and the front of the cartridge without the stylus. I am just curious if the stylus shank is damaged.
Here they are. I think they're a little blurry, but I hope you cam still make it out.
A bit blurry, you could essentially buy a cheap replacement stylus to see if that will fix the problem. But, if you are truly unsure, like many have stated before there are tons of choices.
Okay, I can get one for around $15-20. That's not bad just to see if it works. If not I'll have a spare needle for a future replacement.
Hrmm wished I knew they still made the digitrac stylus before I sold off my OM10 cartridge!
Nope - has not been made since the 80's I believe - that brand tanked...
All the digitrac stuff now is NOS that was not originally sold due to the failure of the company.
Yep - check it is all fine - make sure it is all properly aligned, and then look into a better stylus!
You can get a HyperEliptical or even a SAS stylus for that cartridge....
Any of the pfanstiehl 760 designation needles should fit....
http://www.turntableneedles.com/Needle-760-DE-copy_p_1385.html
http://www.turntableneedles.com/Needle-760-DEJ_p_1386.html
http://www.turntableneedles.com/Shure-N74CZ-Needle-760-D7Z-copy_p_1384.html
http://www.turntableneedles.com/Shure-N75HE-Needle-760-DHE-copy_p_1076.html
Other Names/Designations for the same thing (from Turntableneedles - very handy site - also a reputable and reasonably priced vendor)
• DUAL MODELS CS701 CS704
• ASTATIC NEEDLES N642 N971
• DUAL NEEDLES DN-330 DN330
• FIDELITONE CARTRIDGES 304E-593 304E593
• FIDELITONE NEEDLES A593
• GARRARD MODELS GT35AP SLX3
PACIFIC M73PED
• RADIO SHACK MODELS 42-2769 422769 42-2770 422770 42-2976 422976 LAB-58 LAB440
• RADIO SHACK (by SHURE) CARTRIDGE R25SED R1000EDT R25EDT R255ED R1000
• RADIO SHACK (by SHURE) NEEDLE RS3E RS700E RS5T RX8
• RADIO SHACK CARTRIDGES 42-2767 422767 42-2768 422768 42-2769 422769 42-2770 422770
• RADIO SHACK NEEDLES RS610 RS8T RS6E RS87 RS8E
• RECOTON 304E-794 304E794 SP794
• SHURE NEEDLES N75EDTYPE2 N75ED-T2 N75EDT2
• SHURE CARTRIDGES DT20E M75E M75ETYPE2 M75EDTYPE2 M75MGTYPE2 M991E M993ED MT200E PremierSeries-Black PremierSeriesBlack R27ED R6X PRESENCE3 R27E M993ED M75MG-TYPE 2 RS5E M75E-TYPE 2 R700E DT20E TAE2 RS700E RS5T M75E M75B-TYPE 2 M73PED 375DE 9758ED AA92E AM92-ED AM97EE BLACK DUIO-M75ET2 ETS-109E HTE M101EG M200ED M2291EH M291ED M3010SW M391ED M491ED M591ED M705EX M73PED M7500ED M752ED M75EDT2 M911ED M991ED ME910ED PHASE1000-4 PRESENCE3 R1000-ED R27E R700E RD101 RD191 SL95-M75ET3 T40-1 TAE3 TM2E TM3E Z7575ED DUIO-M75ET2 DUIOM75ET2 ETS-109E ETS109E PHASE1000-4 PHASE10004 SL95-M75ET3 SL95M75ET3 M75EDM
• TRANSCRIBER NEEDLES PS630
