We don’t all hear the same what sounds great to you may sound ok to me. It’s like do you like sugar with your coffee or not. So the tone controls are my sugar with or without. I like the option that’s all I am saying.Well a few members mentioned that already on page one. However you keep saying that EQ and Tone controls are a needed necessity because of bad recordings. I say that's nonsense because we all get the same music relatively speaking. Your perceived need comes from how you got used to listening to the music, your system and speaker interaction with the room.
How do you know before you buy? Not trying to be a smart ass but a legitimate question.I pretty much avoid this issue by not bothering with lousy recordings.![]()
i'd rather have my lousy recordings of, say, Blind Blake, or Blind Lemon Jefferson then a modern musician doing his songs.I pretty much avoid this issue by not bothering with lousy recordings.![]()
Not sure if the FVA mod changed the profile, but the stock bass control is +/- 16 db at 50 hz. You always need that kind of boost? Holy cow!
With the HT, I needed to attenuate 53 hz by 9 db and 62 hz by 6 db and still cannot entirely get rid of the 3 db rise at 50 hz and still have a null at twice that frequency. Perhaps your challenge is a severe room null - which is effectively a black hole. You can pour boost all the want in those cases and really get nowhere.
Schiit offers the Loki for those who wish to add tone control functionality to preamps lacking such.
Got a old Dynaco Pat-4 modded by VanAlstine back in the 80’s and have a modern tube preamp without tone controls and it sounds just as good
Yep this is perfectly understandable.We don’t all hear the same what sounds great to you may sound ok to me. It’s like do you like sugar with your coffee or not.
This is understandable also and you do have options.So the tone controls are my sugar with or without. I like the option that’s all I am saying.
Yeah I actually do have a few examples of lousy recordings and I do listen to them once in a while as they are.i'd rather have my lousy recordings of, say, Blind Blake, or Blind Lemon Jefferson then a modern musician doing his songs.
Research and experience.How do you know before you buy? Not trying to be a smart ass but a legitimate question.
What's not understandable is saying manufacturers are eliminating tone controls because they are trying to rip us off, or they are pinching pennies and charging us a lot anyway. It's a known fact the shortest path the signal takes improves SQ. The less switches in a box reduces noise getting in the signal path. So most TOTL or flagship in a real good manufactures line up generally don't have tone controls built in. They are trying to build a specific unit to have the best qualities for sound alone.
Not all media is the same, not all systems are the same, a title might sound bad on one system and good on another. A EQ is only masking the bad, it's still there but while it's filtering what one perceives as bad it's also filtering the music in that frequency range that's being compensated for.
If you go back and listen to those two vids I posted you can hear the difference a different amp and speakers made with one track on a record. In the first one I knew it sounded bassy and at around 1.25 minutes I tried to turn it up a little and the bass got overwhelming so I turned it down as it was distorting. The second vid was a different amp and speaker setup and nothing else was changed but it sounded far far better. The fact is, it was my system and the media that wasn't working good together until I matched the system with the media better all without tone controls.
Yep me too, but I do have the option to switch speakers and amps to fit the music better, or even loading and gain when playing records.Yeah I actually do have a few examples of lousy recordings and I do listen to them once in a while as they are.
So trueResearch and experience.
Better only works if it's matched up good. I have never found one speaker or amp that does it all really good. This is why I have one system with three different types of speakers and then I try to match amps to them, or the other way around. But all my front end and preamp stays the same without tone controls or any EQing.It's amazing how better equipment can sound better, simply amazing, funny how it works that way lol.
And not just better, but better synergy will also play a roll eh?
Hence my comment about synergy eh?Yep me too, but I do have the option to switch speakers and amps to fit the music better, or even loading and gain when playing records.
So true
That Mavin Gaye WGO one step, people where complaining it was really bass boosted, I can totally see that. At least with one out of three amp/speaker options I have it was, the other two it sounds great. So it begs the question, was it MFSL fault in mastering or the way I set my system up, or choice of what I am using.
Yeah, but I take it a step further, or I should say two steps further past equipment synergy.Hence my comment about synergy eh?
And this is why I don't mind when a mastering lab takes a master tape and records a high rez file to work in the digital realm. They can pin prick out sibilance or other abnormalities for a split second instead of filtering out that entire frequency range through the whole track with a analogue De-S-er.I don't use tone controls because they never adjust only what I feel needs adjusting, rather a too wide range which almost always sounds much worse (to me) than leaving them flat. It's like needing a tiny pinch of salt but only having all spice to put in a recipe. You get the salt but also a whole bunch of extra stuff that you don't want.
1) Matching the type of music with the speakers and amps since I have that selectable option with a flip of a switch.
2) Changing loading and gain on my vinyl front end staging as well as a couple different DAC options with the flip of a switch to match the masterings better.
Like here, this is the same setup that WGO sounded bad with, but the MLs sound good with mystic music, as the room glows. I'm walking around here and it still sounds good everywhere and at the end as I sit down in the sweet spot it's just better.
Here we have the same music, disregard the table setup as it's still staged the same as my SOTAs and a Sumiko EVO III. But it sound really bad because of the ADS 1230s and even worse walking around.
Remember what I said it is just my opinion and the way I hear it. So that being said not gonna throw that product under the bus on here.I have to ask: what modern tube preamp is no better than a Dynaco PAT-4?
