Would you rather have a Technics SL-1600, SL-1600 mk2, or Pioneer PL-518?
sunvalleylaw
AK Subscriber
I am curious as I am shopping. Would you rather have a Technics SL-1600, SL-1600 mk2, or Pioneer PL-518? And please say why. Thanks!
All things being equal (similar condition, reasonably equivalent pricing), I’d take the SL-1600. Mostly because I prefer the front-of-the-unit control setup to the other two. Also, quartz lock, which I wish my JVC had.
Wanna buy a vowel? The II has the outside the cover controls and is quartz locked. The SL-1600 is servo controlled.
I have a 1600II and had an 1800II so I guess I'm with everyone else, the SL-1600 II is the one to get.
Dammit. Yeah, that should have been Sl-1600 Mk II.
Another vote for the 1600 MK2 here, for similar reasons to those already mentioned. I've got a 1700 MK2 and worked or owned the other models as well.
I prefer the original SL-1600 / SL-1700 version for it's simple and effective arm movement design. IME the SL-1600MkII and SL-700MkII arm movement mechanism is overly complicated and trouble prone. Sometimes it's just the "O" ring, sometimes it's a cracked gear.
I have the mkII and just sold 2 sl1700's. I wish I would have kept the 1700 due to its simplicity. My 1600mkII has been a headache since I bought it a year ago.
My $0.02.
I know what you mean. I also like the simple designs of the SL-1300, 1400 and 1500 with no strobe dots.
Derailment: I actually like the PL-560 just as much as the SL-1600 if we want to be fair, minus those crappy feet. But, the SL-1600mkii has just more fun features.
Not familiar with the Pioneer, but I would also recommend the SL-1600MkII, provided it functions. It may be a headache to fix it if it has problems. The only expected fault that is easy to fix is the tonearm cueing belt that gets loose or snaps. The electronics are a headache.
Additionally, the MkII will most likely require adjustment of the spring loaded feet to make the suspended sub-chasis horizontal again.
If you don't really need an automatic turntable, a 1200MkII would be a great choice as well. Same tonearm, simpler electronics and endless potential for tweaking.
The PL-518 is a pretty fair piece that seems to just continue to work. It's a simple and capable unit that sounds quite good with a lot of cartridges that won't break the bank.
Its plinth is also incredibly easy to veneer or just replace altogether. The guts and placards are easy to remove, and building a custom plinth is a relatively easy option (yes, woodworking required).
With a little patience and luck, a PL-518 can be found in good mechanical condition with poor cosmetics for cheap enough (under a hundred) so that someone with the requisite skills could have a really handsome and capable deck for cheap.
Here is one in white oak
Here is all there is to the plinth. This one is lace wood over a laminated veneer core and just needs to have the innards and feet put on.
