Did you check if you had a C2 Power Supply board?TR411 has 7v on the collector and TR412 has .1 v on the base-- need .6v at least to bias on TR412 .. Don't make since.. Unless you have another crack in the board. Or another error in the drawing.
C2C-2 or C-2a ?
Post #25?Maybe 4-6 small prongs on the underside need to be bent out to remove the slide switch from the mechanical lever.
Look at post # 25
https://audiokarma.org/forums/index.php?threads/akai-am-2800-resurrection.675706/page-2#post-9094659
771-NZX3V9C,133 possible replacementD403, 404, 407, 408, 414
Marked on schematic as WZ061
Actually installed 4786
WZ061 = 6.0v
4786 = 4.0v ?
