You might want to check with other users ( and their use of the N1201-8a with Valencias ) but it's my impression that most seem to run their horn drive circuits full out & then pull down the midrange to balance out the sound. Doing so, offers-up the most HF//UHF output.
If you find yourself doing similar, then the .33mH coil has been taken out of the circuit ( bypassed by the horn-drive, 8R variable resistor being effectively set to 0.0R ).
Both those components could then be eliminated from your final build ( again,, if R1 is wide-open.
Additionally, one can squeak a bit more HF out of the circuit by reducing the 3 ohm resistor ( R6 ) to as little as zero ( & then again, adjusting R3, the midrange variable pot. for best balance ).
