In addition to my previous post where I described the limitations I encountered of measuring the force applied by an antiskating mechanism in a tonearm, I didn't elaborated on why this is so (or at least, I assume it is so).
To measure that antiskating force from the tonearm with a sideways tilted digital scale sensor and come to reasonably consistent results, the tonearm had to be moving towards the sensor and come to a stop from a movement that was as slow as possible. Resting the tonearm against the scale and fiddeling with the dial gave very irratic results of such magnitude that they were not useable to graph out the antiskating force curve.
I believe this is the result of the difference between kinetic friction coefficient and (maximum) static fricton coefficient in the bearings of the tonearm.
The maximum static friction coefficient is much higher than the kinetic friction coefficient. A curve that displays both (so applying a force to an object to the point that it suddenly starts to move) typically looks like this:
Of course you only want to measure antiskating force in the situation of the kinetic friction coefficient. This is also the only situation that occurs when playing a record, because the tonearm is always moving when playing (there's the movement gradually along the groove, and potentially movement of an off center spindle hole). But a digital scale sensor of course is stationairy.
Designing a sensor base that is moving very slowly but consistently and in the arc of the tonearm that is very compact at the same time so that it fits under the stylus.... might be an impossible task.
I don't know if a wallyskater displays this same effect in the same extent or if it's less, because that is a measuring system that comes to a halt. I'm planing to build one and that is the first thing I want to investigate. The manual does describe static friction and to take multiple measurements, but I think this is potentially easier and and more consistent.
However to get precise results from a wallyskater, the scale on the deviation is not linear despite what the manual says. That is a fundamental flaw in it's design or at least in the manual. The path of the tonearm on a string is an arc, so every linear step it takes away further from the vertical 'zero' string, comes with relative more antiskating as the tonearm has to be lifted relatively more on that same linear sideways step.
So that scale of steps and how many percent of the VTF each 1cm (or whatever step) is, has to be recalculated for each step. Doable, but my trigonomitry is a bit rusty
There's still so much to research in this particular field as information is so scarce. Probably due to that side force checkers/skate-o-meters have only been sold in the past in very very small quantities and that there is no alternative version for sale today (or in the last ~30 years).
And reseaching all these things, making custom contraptions etc takes a lot of time.
My goal is for example in the end to come up with something like a transition table based on the basis of a signal strenght/dynamics and stylus profile a certain ideal antiskating force can be appointed so that people themselves can measure that antiskating force on their own system (either with a diy improved wallyskater or maybe an improved diy system based on a digital scale)
So that people that are in doubt of the precision of their antiskating dial (or don't have one like on clearaudio and reed tonearms) can dial in a realtive precise AS force just by building a fairly simple wallyskater instead of hunting down a skate-o-meter on ebay for years and spendig hundreds and hundreds of dollars on it.
