Dead main motor on double motor AR-XA
cmarti
Well-Known Member
The main motor on my early XA turntable failed today, what are my options at this point?
Are the coils open? if not, disassemble, wash it and re-lubricate and replace the capacitor, (has to be the same value non-polar and 400+ Volts.
finding a Haydon motor.......kinda hard. A Hurst 3001-001 motor is easy enough to find. you'll need to run a .25uf 600vac phase cap, and you'll need to get the proper pulley for it. The original motor was 600rpm, replacements will be 300rpm.
the coils are open I opened it and it was well lubricated. (I had used Amsoil synthetic oil to lube both motors) I read some people rewire them?
Thanks, what about getting that DC motor upgrade offfered at Audio Nirvana?
I know nothing of it.
That's not a DC motor, that's simply a hurst motor that george merrill puts his name on.
It does come with a power supply which you connect to the wall, it converts the current to DC, maybe 12 or 24 volts.
I would just like to find an original replacement and call it a day, perhaps someone here has one for sale? :)
No experience with one, but I think there are advantages to an aftermarket motor kit. I did a bunch of tests on motors some time back and concluded that getting a decent synchronous motor these days is tough. They can be noisy (as in I hear the motor running) and are not of the same consistent quality as the USA-produced Hurst motors of long ago. One can special order special versions, but that's not much use to the individual. If one were really serious, a decent DC motor from Maxon, and suitable control circuit would be the way to go, but those motors aren't cheap. I think there were some threads on this over at diyaudio a while back.
