@loaded Do you have an Android or Apple phone, and do you have an RTA on it?
Do you have a test track with pink noise?
Reverse the wiring to the horn, play pink noise with the mic on the axis of the horn, move the horn
back until you see the deepest null in the response. Now put the horn polarity back to normal.
You can also simply try reversing the horn polarity on the theory that you've got weak output
due to a null, if this is true the output will significantly increase - how does it sound?
You should place the woofer as close as possible to the horn to minimize the center to center (CTC)
spacing which will improve the vertical polar characteristics. Or, you could have placed the
woofer lower, leaving room to mount the horn on the front baffle, again as close as possible
to the woofer for the best polar response.
Note the CTC:
https://www.crutchfield.com/p_700CW4BA/Klipsch-Heritage-Cornwall-IV-Satin-Black-Ash.html
