I listened to them a bunch this weekend and they sound pretty good, but the bass is too boomy on certain songs I like, and I like bass. I'm going to spike the stands and test them some more. Also, I have zero room treatments as I have not had the time to buy new panels, etc after we moved. I tried positioning them, still too much for me. I like my music pretty loud, not sure these will cut it.
The insides have 4 strips of fiberglass, but under the PR and the woofer is rolled up poly with the ends pointing towards the drivers which is interesting. I'm going to pick up some more fiberglass, remove the poly and stuff them some more and test. I might add the sonic barrier to one and test that too.
I know my space is probably contributing to this, and I might have to test them with different stands, tweeter at ear level and off the floor more. I will say this, some songs sound fantastic.
Are you running the tweeters attenuated?
These speakers reach to the very low 30s and if your room has modes, as all typical home rooms do, they
will be revealed. Some fix this by using mini monitors with virtually no bass below 60-80 Hz.
As I said the woofer is not well suited to a vented alignment, Qts is too high, and the way to fix this is to
pack a lot of fiberglass directly behind the woofer to increase the woofer damping not the box or PR
damping. Best thing would be to measure them in your room and if the boom is around 32 Hz then
reduce the box volume, say -.5 cu ft. If the boom is 50 to 100Hz increase the woofer damping, and some
of it is going to be the room, adjust placement and room damping. But room damping at such low
frequencies that it is not easy.
As far as playing them loud goes consider that they have only a 1" voice coil wound on a paper former
from what I can see. That 8" woofer is not going to handle major power.
If you want to be blown away, get PSB Stratus Golds, these are on another level, completely.
I've fed them with 325W/ch into the 4 ohm load and driven them with the clipping lights flickering.
They'll play about 6 or more dB louder than these Genesis speakers.
Read Don Keele's review in Audio.
