Yes this is pretty much live Pingu, I just broke for dinner and finished off the p800 board. As you can see in the photo's, the glue on the bottom side of the board began to corrode the 100uf caps. All values were upped on this board as well as replacement diodes- UF4005's.
C803 was 470uf it's now 1000
C804 was 100 it's now 220
C805 was 330 and is now 680
C806 was 100 and is now 270
Pre replacement-
Post replacement-
The "bad caps", the leads simply broke off and were rusted.
I'm now going to fire it up and give it a listen.
Lee I need to be schooled a bit here:
Installing the UF4005 diodes on the P/S board, the originals SIB-01-02 are 200V with 1 A forward voltage so from the spec sheet it looks like you could bump it up to a UF4004, at UF4005 the forward is now 1.7. Does that really matter? And these would be fast recovery diodes, why not soft recovery here, for lower noise.
Instant power upgrade gents-the power output is back! It could be made to be loud at around 5-6 on the volume dial, now it's more like 2 or 3. I measured the coupling caps for fun, they were sitting at around half their rating, I kid you not!
Good old rust glue lol, guess the manufacturers didn't realize they glue would do that.
