Beautiful. I love the casework too!
cubdog
I have 2 units: Bottom unit is Philips AG9016.Top unit is 807 in Triode Mode
1)Philips AG9016—2 WPC—Here is a good link to some info about this great little integrated:
http://www.audiokarma.org/forums/showthread.php?t=70653
2)807 SE connected in Triode Mode—Commissioned AbraxsAudio (Jeff Larson) to build this unit in 2004. 807 pair is NOS RCA JAN perfectly matched. The Sylvania 6LS7 round plate in the front is the input/driver tube. A vintage RCA 5V4G provides the power. We managed to achieve 1.7 WPC. The 807 handles a bit over voltage without breaking a sweat. It sounds MUCH larger than the watts would indicate. The response is ruler flat from 30Hz to 30 KHz. It sounds great. It handles about everything I toss at it with ease (horn loaded bookshelves).
jaymanaa--It has been more than 15 years ago that I found this unit at a flea market (paid 15 clams) I could not find the original Philips connectors (before EBAY) so I added RCA inputs for turntable and speaker outs. See back panel photo. Today I could only find a few scribbled notes.
As you can see, looking at connector at PHONO stage (reading holes left to right), I found that input 1-3-5 are ground but cannot remember which is for left ground-right ground and stereo ? I found that NO.2 is LEFT+ and NO:4 for Right+ !!! (I was only interested in turntable connections). My notes say I looked into the tape connector, I think I was interested in CD player for that one. At the tape connector I believe #1 (reading left to right) is LEFT +, NO:2 Right + and NO:3 Ground and use this Ground for both LEFT and RIGHT?? Then I had question marks so never really made the change. As you can tell I was doing this by the seat of the pants. A little later I changed my main system to Scott 299C and Thorens TD124 and never looked back as far as phono playback. With the 807 project completed it became a bedroom/reading room system with only CD player connected. Awesome sound---when used as almost near-field.
Wow Mickey, those look really great. Can you tell us more about which transformers you used?
Beautiful work here!
Thank you!Beautiful. I love the casework too!
cubdog
On a funny note, I've been building a pair of triple parallel 2A3s monos with a separate power supply chassis. I got the power TX for the just the signal current for the 2A3s yesterday and just weighed it. It came in at 43 pounds even, which is going to put this power supply chassis over the 100 pound mark by my best guess. The main input choke is 16 pounds, and the two individual chokes for each channel are 5 pounds x 4. Then there's capacitors, filament transformers, front end signal current transformer, and the chassis itself. Snikies! This is what happens when you go through the Douglas school of SET power supplies.![]()
13EM7 Minibloks, 1.5 watts of power. This was my first scratch build, it consists of only seven capacitors and six resistors. They are used in my den, powering a pair of Paradigm Micro speakers, connected to a Sony CD player with a TDA1543 DAC.
