kevintomb
Well-Known Member
That's a good point and very possible for my JVC example because the amp and speakers in "all-in-one" systems can have built-in EQ to compensate for what are always bass-challenged mains, but it's not the case for any of my other systems using speaker-level -- those are analog 2-channel only with no active EQ.
Again, I would never recommend speaker-wire for theater use, but I prefer speaker-level for analog 2-channel in my direct experience. I only recommend that people try both (for 2-channel only) and determine what works for them.
For those who believe that all amps sound the same, its easy to see why they also believe speaker-level can't have any benefit. For those that don't believe all amps sound the same, they don't really have a leg to stand on to say the using speaker-level can't be beneficial (<- that doesn't mean it "will" be beneficial, it only means the amp can make a difference in how the sub sounds when connected by speaker wire). There are no "absolutes" about which is better -- that will depend on individual room acoustics, the specific system components used, and the types of music played (e.g. techno with ULF content vs jazz). The best approach is to try both for 2-channel, and stick with the one you prefer (and report back so we all benefit from your experience!).
I have done it both ways, and honestly think more in theory it is a lesser signal by using the high level inputs.
The difference was not what I am talking about, but more the potential for there to be slightly more degradation, if that makes sense.
As far as amps, I do not recall anyone saying all amps sound the "Same", but I do for sure feel that many are similar enough to not alter the signal enough to make any significant difference.
