LP-THORN
The problem is not replacing the bearing, the problem is that for overhauling (and then calibrating) the electronics you need to put the turntable upside down and since this involves putting the top plate upside down, the bearing drips all its oil which can contaminate the surroundings if you're not careful.
You can avoid this by removing the top plate first but to do it you need to unscrew the top plate retainers which involves... putting the turntable upside down (unless you have a special jig where you can easily access the underside.)
How often does the TD125MK2 require service? Not often but the switch contacts are somewhat exposed at the bottom and in my TTs they tended to get dirty from time to time. And the electronics are fragile; the ua709 opamp is VERY fragile (but fortunately can be replaced with a modern opamp if you know what you are doing), and the light bulb that is part of the circuit is critical and made of unobtanium. DO NOT touch that light bulb... the exact specific type of light bulb is necessary for the correct working of the circuit!
I have written more about the TD125MK2 in this or other forum. I owned two of them. One of them had the deluxe SME base and looked terrific. By the way, the best you can do for sound is to remove the suspension springs and replace them with rubber supports. You get a slight bit of rumble but it is worth it. At the end i replaced it with the Sony PS-2251 which sounded better with the same tonearm and cart.
Yes but those problems are always just caused by hardened grease, which frees just by strategically applying some solvent. Relatively easy. The 1229, on the other hand, has the VTA adjuster problem...
flavio81,these are minor points that do not actually detract from a turntable's sound which afterall is what the buyer wants.
The oil will drip from all turntables like the 125 (linns,aristons,systemdeks and so many other otherwise excellent turntables).Does this mean one must avoid buying one?I own 4 such turntables and I'm happy with all of them,as I am also with my Garrard 401.
Modifications like rubbers in place of springs,actually compromise the performance of a suspended turntable as it was intended by the designer,as you also say yourself in your comments,that of course are purely subjective.You may accept to live with the compromise of rumble,while others may not.
Don't forget also,that talking about vintage turntables, yes, some points/details can be done better today.
