I actually had two projects today.
First was an Onkyo M-5150 Power Amp, which has just replaced the Onkyo M-5140 in my living room (main) system.
The M-5140 is rated 105 w/ch rms at .09% distortioin. It has +/- 60 v on the rails, and uses the Sanyo STK4044V output chips.
The M-5150 is rated 150 w/ch rms at .09% distortioin. It has +/- 71 v on the rails, and uses the Sanyo STK4048V output chips.
These two amps, other than the transformer and output chips, are otherwise nearly identical.
I used a chemical to blacken some minor scratches on the black aluminum faceplate.
Then I opened it, dusted it out, and added 5-way binding posts just above the original speaker spring clips thingies. Parts Express p/n 091-1140, similar to what I had done with this M-5140, and placed photos here on AK:
The M-5150 is now installed in my main system.
Second project, an Onkyo T-4087 tuner that I had filter modded previously... (see this thread)
http://audiokarma.org/forums/showthread.php?t=139128&highlight=T-4087
... I had removed the fake rosewood sides, which left an open area on each side of the faceplate.
I had a sheet of black textured ABS plastic which I just received from Parts Express p/n 265-948. I cut some filler pieces, and glued them in place earlier this evening. I used my favorite shop glue, E6000.
