Paul C
I was asked what I use to fix scratches on black aluminum faceplates.
I use a chemical called Aluminum Black (3 oz. bottle 15125 -PAB), by Birchwood Casey. This is found in gun shops. Birchwood Casey also makes Perma Blue (aka cold blue), Tru Oil (linseed oil -- for stock refinishing), and other products for gun care and maintenance. You can buy Aluminum Black from www.brownells.com or
http://www.birchwoodcasey.com/sport/index.html
The chemical will only work on unanodized aluminum. That is, it will only react with the scratches. The surface must be clean, free of oil, so clean it first. Then dip a cotton swab in the chemical and rub on the scratch. Keep swabbing over the scratch to remove reacted chemical and bring fresh in contact with the metal. If you look closely you will see it bubbling. It will not make the scratch completely invisible, but will darken it so that it is not immediately noticable.
The chemical is quite corrosive, so do not allow it to drip into the unit you are working on. It is not necessary to use a lot of the chemical. That small bottle will last for YEARS if you keep the cap tight.
When done, wipe away excess with a paper towel, then clean the surface again... I use glass cleaner. Wash your hands.
Here is an "after" photo:
Can you see where I fixed the scratches? If not, I'm not going to point them out to you.
I will say they are far more visible in this photo, with the flash, than they are with the unit sitting in my stereo cabinet under normal lighting.
