The 180K resistors aren't "necessary" there to help bias the driver tube better.
(if one was to measure the bias voltage with and without them you'd see it)
The .22uf caps are larger then they need to be, .047uf - .22uf are fine in there.
(I tend to find .22 a little fuller sound cap then a .047 is quite often, I use .22)
Anyway good to see you got it straightened out, if yu feel like taking an posting
voltages (plate and cathode of all tubes) we can see how your circuit is running.
I don't know if I'm taking these measurements correctly. If pin 3 is cathode and pin 7 is plate on the el84s this is what I've got. 20.1v and 20.3v on cathode and 602v on both plates.
I would use anything between an .047uf - .22uf for the coupling caps.
.1uf would be right in the middle, .01 would be lower then I would use.
Oops. How's 9.6 and 9.7 at cathodes and 274 at plate.
I'd like to learn to dial the sound in to taste. I find the mids a bit edgy and would like to tone them down. Also wonder if there is too much gain. At anything above normal listening level produces audible distortion. I'd like some head room there. What sections of the circuit control control gain and tone?
The only things that differ in my build from Keggers design is the removal of the 180K resistors and 470Ks instead of 270ks at the inputs.
Adding on: I played around with different resistors at the input without much noticeable until I put it a 100k and had very little signal. Then I put a 1M to ground and a 100K volume pot. With that I was able to push more volume out before it began to distort. How can I replicate that minus the volume pot?
To add volume control, change the 270k resistor on the front to 1meg and
add an 100k audio taper pot like say one of the alps ones from radio shack
to control the volume, no added gain is necessary.
