Kegger
R.I.P. 1/12/1966 - 6/1/2017
The only place the caps make a difference in the supply voltage is the first cap in the
supply in cap input power supply on upto about 47uf, beyond that there is no change.
The rest of the caps do filtering an reservoir/energy storage on that amp, the place to
put your reservoir/tank is where an output transformer/output tubes take there supply
from, in this case it is the 150uf cap after the 100ohm resistor, here it is really doing 2
functions supply the reservoir and doing needed filtering/cleaning, as we haven't much
filtering go on before it with a 50uf cap and 100ohm resistor, choke in place of resistor
would do better an we could possibly use a choke with less then 100ohms to get more
voltage out of that supply then as well there to. Single ended amps tend to have little
to no power supply noise rejection so I feel they need to be well filtered, the push pull
amp does have some power supply noise rejection/cancellation but then with generally
running 4 output tubes compared to 2 the capacitance "reserve" wants will go up.
From my perspective the reservoir cap/tank size needs change with the type tubes or
shall we say power of an amplifier, a single ended 6v6, el84 amp 100uf to say high side
of 330uf be the extent of any benefit, but lower then 100uf may not be adequate here.
Where on the 6L6 through kt88's you may want a 220uf to 470uf reserve storage there.
A push pull amp running 4 6v6, el84 say 1.5 times what the single ended version used,
to the tune of 150uf to say on upto 470uf, larger bottles like 6L6-kt88 I'd like to see a
tank of say 330uf on upto say 750uf before the law of "diminishing returns" start to set
in and your larger caps don't really do much for you any more.
(some also feel to large of caps start to degrade the "sound" of the amp) :scratch2:
Now also we need to take into account what it takes to fill these caps, an it can take
a fair amount of power transformer energy when you go to large on those caps, say a
transformer your thinking is on the wimpier side I wouldn't go beyond 220uf in a supply.
Lastly the RC filtering stage feeding the front end, again not a ton filtering done in the
amp prior to this stage so to keep it quiet I used 60uf there, there is no need to build
a reservoir here it is purely for filtering, on most of my amps where I have room for an
adequate supply Before this stage I tend to only run 33uf here as more is not needed.
Cathode bypass caps are probably chosen originally a value that limited bass response
either for the inadequate power supply, speakers used on the amp, output transformer
lower bandwidth and or limiting the power consumption of the amp, but most of us use
these amps as stand alone units, so all that extra stuff they originally powered is gone.
(I generally use between 150uf and 470uf output tube cathode bypass caps on these)
So to sum it up the first cap sets the voltage and 47uf is high side input cap, from say
20uf to 47uf you'll have little change in the output voltage. (47high for tube rectifiers)
150uf-330uf is a decent place/size to upgrade these console amps power supply caps
to in the sections that actually feed the output tubes power, if there's a choke supply
then the stages feeding the front end/drivers 33uf should be fine for those stages but
if no choke and not much filtering upto that point I'd suggest 60uf better value there.
Anyway that is how I treat most console/vintage amp rebuilds that I feel have smaller
then really is adequate to get the job done very well with there original supply designs.
