cephelps
OLD SCHOOL
That little maggie is not a bad little amp at all, the design/redesign was basically
a cleaning up of the signal and making things run a bit better then stock really.
(your rebuild looks quite nice, there are better circuits then the maggie here)
Since your running single cathode resistors on the outputs you did remember the
value change doubles from what the shared resistor values that were in there. :scratch2:
Here is an update to what you have given me, and I did miss on the caps. I noticed that I use the 150uf caps. Today I found a pair of 250ohms resistors, and I will add them to the 300uf caps I have. Thanks for the reminder.
